Hi team,
I am using Infragistics version 9.1.28 and will update in upcoming month but this is requirement i have to deliver.Requirement: Using Hierarchical Grid i have to load child data on demand.Issue: HTML:
Can someone please reply. it is urgent.
Hi Shobhana,
As mentioned in other forum posts we have recently discussed in, Ignite UI for Angular and Angular version 9 are long expired and are not eligible for developer support services.
Consequently, the issue you have referenced has been fixed and released for version 9.1.x, so your project most likely includes the fix. This means you do not have to implement an additional workaround.
It is possible, however, that other issues related to the scenario in question have been fixed since that version. Having in mind that the Hierarchical Grid Load On Demand demo in our documentation demonstrates it working as expected, this indicates a possibly local for your own app issue.
My suggestion is to compare your code and the code from the topic. There might have been some slight API changes, such as the onGridCreated event renamed to gridCreated, however, you could use the API pages to determine if there are any differences in the methods and properties you are using. The overall approach would not have changed, though.
So, I am afraid we cannot really determine the root cause of the issues you are facing without a reproducible sample in a supported version.
Nevertheless, I am wondering about the code in the gridCreated event handler from the provided code snippets. The following line assigns some “Data” variable to the event.grid.data
event.grid.data = Data;
however, from the code snippets it is not visible where this variable comes from or how it is initialized. Without any other clues, I can suggest debugging to verify the value of this “Data” variable when it is assigned to the event.grid.data. Otherwise, there is no reason for the data not to bind, that I can currently identify.
Best regards, Bozhidara Pachilova Associate Software Developer
I found the solution. Issue was as i was using both keys and primaryKey property for igx-rowIsland.
I am glad that you were able to find the root cause of the issue. Thank you for using Infragistics components!
Can u please help me to achieve a requirement where i want to expand the first row by default. As i am using 2 seperate API's for showing parent and child data.
I noticed there is another forum thread, where the same question has already been posted. Please, keep in mind that according to our support policy, we handle a single thread per question. This helps ensure that all your questions are addressed correctly.
Additionally, we advise that each thread covers a single topic to ensure better consistency. Thank you for understanding.
Please, refer to the other thread where I have already provided an answer to your question.
