I'm trying to use a linear gauge in Xamarin Forms and make it look like this:
So far I've been able to get it like this (I know the purple isn't above, but I made it to show the extra space at the end):
But the label text is cut off and the graph border has extra space on each end. If I make the graph huge then nothing gets cut off,
but that also does not fit my design requirements. I need help with the label text not getting cut off and eliminating the space and the start and end of the graph. My XAML code currently is:
<ig:XamLinearGauge NeedleShape="Triangle" NeedleBrush="#FFFFFF" x:Name="TestGauge" FormatLabel="TestGauge_FormatLabel" NeedleBreadth="7" NeedleInnerExtent="0.70" NeedleOuterExtent="0.8" MinimumValue="0" MaximumValue="100" Value="{Binding NeedleValue}" Margin="0" LabelInterval="{Binding NeedleValue}" BackgroundColor="#0070b9" BackingOutline="#FFFFFF" BackingStrokeThickness="1" BackingInnerExtent=".32" BackingOuterExtent=".77" LabelExtent="0.85" HeightRequest="35" Interval="100" TickStartExtent=".5" TickEndExtent="1" TickBrush="#00FFFFFF" MinorTickCount="0" BackingBrush="#0070b9" FontBrush="#FFFFFF" NeedleOutline="#00FFFFFF"> <ig:XamLinearGauge.Ranges> <ig:LinearGraphRange StartValue="0" EndValue="35" Brush="#4BBF81" /> <ig:LinearGraphRange StartValue="35" EndValue="75" Brush="#ffcc66" /> <ig:LinearGraphRange StartValue="75" EndValue="100" Brush="#592c82" /> </ig:XamLinearGauge.Ranges> </ig:XamLinearGauge>
I do have an event in the code behind to change the label text. Any help would be appreciated.
Hello Dan,
I have been investigating into your requirements with the XamLinearGauge in Xamarin.Forms and I have some information for you on this matter.
First, in order to remove the space at the start and end of the graph, I would recommend setting the ScaleStartExtent and the ScaleEndExtent properties. For example, if you were to set these properties to 0 and 1, respectively, this would make your XamLinearGauge take up all available horizontal space.
Regarding the Label, you can move the range area of the XamLinearGauge by providing a RangeInnerExtent and RangeOuterExtent property. These properties take values between -1 and 1. For example, if you were to set the RangeInnerExtent to -1 and the RangeOuterExtent to 0, this would have the XamLinearGauge’s ranges extent from the bottom of its container to the halfway point.
I would recommend playing with these properties to see where a good fit for the XamLinearGauge is for you.
Thank you for that. Those were the settings I was needing.
