My chart doesn't show X-axis labels. My data is a list of objects. This is the object:
public class DealDataChart { public double DealBuyAmount { get; set; } public DateTime DealDate { get; set; } }
Do I need more data?
I just want the DealBuyAmount (Y-axis) to be plotted against DealDate (X-axis).
Xaml: <ig:XamCategoryChart x:Name="mychart1" ChartType="SplineArea" ItemsSource="{Binding Path=DataItems}" Title="Deals" Subtitle="(Amount and Date)" XAxisLabelFontSize="16" XAxisLabelTextColor="Red" XAxisLabelFontAttributes="Bold" XAxisLabel="{}{Date:dd/MM/yyyy}" > </ig:XamCategoryChart>
I did try setting XAxisLabelVisibility to Visible but it didnt do anything.
Hello Edgaras,
I have been investigating into the sample code that you have provided, and the reason you are not currently seeing labels in the Xamarin XamCategoryChart is because currently, the XamCategoryChart is configured to use the first string property found on the data item by default as its labels. You do not currently have a string property on your data item, and so no label is shown. This information can be found in the first paragraph of this documentation article.
If you do not wish to define a string property on your data item, you can use the XAxisFormatLabel event of the chart instead. The event arguments of this event will return you the data item that the label is being drawn for as well as a Label property so that you can define what you would like to show as a Label.
