When I build the solution and try to run this on Android device:
...xmlns:grids="clr-namespace:Infragistics.XamarinForms.Controls.Grids;assembly=Infragistics.XF.DataGrid"...
<grids:XamDataGrid x:Name="DataGrid" > <grids:XamDataGrid.ItemsSource> <local:SampleSalesTeam /> </grids:XamDataGrid.ItemsSource> </grids:XamDataGrid>
I get below error.
Unhandled Exception:System.MissingMethodException: Method not found: Android.Graphics.TypefaceStyle Infragistics.XamarinForms.Controls.PlatformAPIConverter.ToTypefaceStyle(Xamarin.Forms.FontAttributes)
I believe the android project might be missing the correct reference. I tried manually adding below references, but still no luck:
Infragistics.Xamarin.Android.DataGrid.dllInfragistics.Xamarin.Android.DataVisualization.dllAlso tried the FX ones, FX.Platform and Core, none of them fix the error.
What references should I add for Android project?
Fixed by not adding dll refferences, but adding a nuget package from LOCAL github
