e.g. an employee reports to two managers.
is this possible?
Hi and thank you for posting!
In order to display a node with more than one parent with XamOrgChart you would need to modify the default template as this functionality is not build-in. A custom implementation for the same is provided with the attached sample. You may use it as a basis to implement your scenario.If you would like to display a node with multiple parents, you may also have a look at the XamDiagram functionality. A sample that illustrates this behavior could be found in the Samples Browser->XamDiagram->Data->Binding Nodes and Connections with Object sample.
thank you Maria, could you attached sample pls?
It seems that I forgot to attach the sample before. Sorry about this. I am adding it now.
I am just checking if you have any other questions on the matter.
Thanks for the example. when I make the model more complex with more many to many relationship, the diagram drawn is very confused. I might need to look at XamDiagram as you suggested.
however many organization has dotted reporting line. it would be nice to have this capability built in OrgChart.
thanks
Thank you for your feedback. You can add this suggestion for future implementation at http://ideas.infragistics.com/ where other users can also vote for it. Often new features and functionality are implemented based on those ideas.
