I need to know is there any pre-coded component for reporting in WPF using Infragistics components?
I am asking this because we wanted to integrate Bar charts of infragistics into our application for reporting propose, but we've found many other types of charts in your library and I was not familiar with some of them. So I am asking for a pre-coded form that I can pass my data table into it and it have options in itself to let user to select type of chart it needs and select fields that it needs and in overall lets the user to select how he/she wants the data be visualized to leverage all charts in the Infragistics WPF set.
Regards
Hello Ehsan,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thanks for information. actually i was looking for a pre coded tool like this one: http://www.onlinecharttool.com/
The reason i am asking this is that there are many charts in the Infragistics library that i am not familiar with all of them. Some of them are fundamentally different as far as i understand. I am not familiar with all charts included in the library (so i am not able to include those i am not familiar in UI!) but i would like to leverage all of them! so i need a (for example) pre coded window which i pass the data table into it and it have enough options (for example let user to choose chart type or select fields he want to visualize) to let users to choose different types of charts (assuming user is familiar with all types of charts - unlike me!).
Thanks for your support
The sample I suggested you see in the Samples Browser (Gallery - Category Series) uses one DataSource and you can visualize it using different series from the dropdown. You can use this sample as basis to implement the functionality you want.
Hope this helps you.
