I'm using InfragisticsSL4 v 10.2 and have an issue when I change the DataPointColor for a Line Chart to DataPointColor.Different i.e. Series.DataPointColor = DataPointColor.Different
The problem can be seen in the images below.
The first image shows when I have changed the DataPointColor to DataPointColor.Different, where the Legend/Series on the right hand side seems to be repeating and shows the Date (x axis)?
Whereas, in the second image, when I don't change the DataPointColor and leave this as the default, it returns the expected output for the Legend/Series with the right colors.
The reason, I need to set the DataPointColor to Different is I am modifying the color for the line chart which works fine for the Pie and Bar Charts; but not the line chart where I get the issue with the Legend/Series not returning what I expect.
Can I please have some assistance with this?
Hello Canon,
Thank you for your post. I have been looking into it and I can suggest you use the approach I shared with you here:
http://www.infragistics.com/community/forums/p/90291/446657.aspx#446657
for changing the DataPoint colors and leave DataPointColor Property to its default value. As I said in the referenced forum thread, you should copy the template for the series you are going to use, in your case line series, because in the sample I used Column Series. Please let me know if you need further clarifications on this matter.
Hi Stefan,
If I change the colours of the line chart, they change fine; the problem, is the series/legend doesn't update accordingly as shown in the images provided before.
Can you please specify whether there is a way to directly manipulate the series/legend colours? So instead of using the DataPointColor Property, then I'll be setting the series/legend colours in code?
Cheers,
Canon.
Thanks for the follow up.
Yes, I managed to solve the problem by setting the Fill property of the Series to have the color I need it to have instead of setting the DataPoint Fill. i.e. Series.Fill = New SolidColorBrush(Color.FromArgb(255, 231, 161, 162))
Thanks again.
