Is it possible to have an item in the XamCarouselListBox highlighted when you hover over the item with the mouse? This would be similar to the default behavior of the XamDataCarousel.
Jason
Hello Jason,
I have been looking into your post and you can achieve a similar functionality using triggers like e.g. :
xmlns:themes="http://infragistics.com/Themes"
xmlns:igWindows="http://infragistics.com/Windows"
<Style TargetType="{x:Type igWindows:CarouselListBoxItem}" BasedOn="{x:Static themes:PrimitivesGeneric.CarouselPanelItem}">
<Style.Triggers>
<Trigger Property="IsMouseOver" Value="True">
<Setter Property="Background" Value="SkyBlue"/>
<Setter Property="FontWeight" Value="Bold"/>
</Trigger>
</Style.Triggers>
</Style>
Let me know, if you need any further assistance on this matter.
Thank you, that worked perfectly!
