I have couple of questions regarding xamcarousellistbox.
1. How could I achieve scrolling with wheel even when cursor is hovered on items?
2. How could I achieve the line navigation and not page navigation when right key is pressed? (the left key works by line navigation)
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I handled the XamCarouselListBox’ PreviewMouseWheel event and in its handler I check if the mouse is over an Item and if it is I manually scroll the items. Please let me know if this helps you or you need further assistance on this matter.
Hi there,
Thank you. It works now.
Regarding my 2nd question, I have handled the XamCarouselListBox's PreviewKeyDown event similar to PreviewMouseWheel event and again manually scroll the items, but it still scrolls page wise and not line wise. Do you have some solution?
wangdu
You have to click on an item, then navigate with right arrow key and you will see that once it reaches the last item in the view, it navigates page wise. I would rather like to navigate still with the line/item wise. (the left arrow key navigates line wise and not page wise)
Wangdu
Hello Wangdu,
I have attached a video, where I follow the steps you described, but it seems like that everything works ok on my side. Please let me know if I have misunderstood you in some way.
Hi Stefan,
Well, I was meaning the right arrow key of the keyboard. Sorry for the unclear description of the problem.
I have logged this with development under ID: 126987 and I have also created a support ticket on your behalf: CAS-104189-M1W4P4 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://www.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://www.infragistics.com/Membership/MySupport.aspx
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
