Our project just started to use xamCarouselListbox and xamCarouselPanel. I found that some times xamCarouselListbox will be blank after click navigation button. I want to write code to make access xamCarouselListbox and force at least 1 list item is in it, but have no idea how to handle this.
Also, in xamCarouselListbox how can I use xamCarouselPanel.executeCommand? How can I access xamCarouselPanel?
Hello TTran117,
In order to control the rotation of the XamCaroiselListBox you can handle the event ExecutedComand of the contained XamCarouselPanel. This event will gets fired every time you click on the navigation buttons and you can perform an actions to disable the rotation. You can achieve this functionality as follows:
private void carousel_Loaded(object sender, RoutedEventArgs e)
XamCarouselPanel panel = Utilities.GetDescendantFromType(carousel, typeof(XamCarouselPanel), true) as XamCarouselPanel;
panel.ExecutedCommand += new EventHandler<Infragistics.Windows.Controls.Events.ExecutedCommandEventArgs>(panel_ExecutedCommand);
void panel_ExecutedCommand(object sender, Infragistics.Windows.Controls.Events.ExecutedCommandEventArgs e)
if (e.Command == XamCarouselPanelCommands.NavigateToPreviousItem )
else {
Regarding your second question, you can check the following forum thread:
http://community.infragistics.com/forums/t/62076.aspx
If this doesn’t suit your scenario, please do not hesitate to ask.
