I am using the xamlMaskedEditor and need to display a tooltip if the text in editor is too long
(this happens because i am limited with the editor size and in some cases the mask is longer than control size..) so i need the behaviour that displays "..." and then allows openning a tooltip with the whole mask value
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
