Hi, I'm using NetAdvantage for .NET 2009.1. I'm using the xamChart to display several series of data. As the data is chronological I'm using the chartType ScatterLine. Unfortunately, many of these series are very similar so it's difficult to tell exactly where each point falls. Ultimately, what like to do is toggle the different series on and off by clicking on the corrisponding item in the legend. So far I've managed to use the MouseUp event to capture when the legend is clicked on but at the time of the click the legend.items collection is empty. Furthermore, I can't seem to figure what item the mouse is even over.
I suspect there's a better way to go about this. Any help would be much appreciated.
Take a look at http://community.infragistics.com/forums/p/32258/176020.aspx#176020. Appears you'll need a custom template for the legend. Vlad included a snazzy sample project also with a sample for checkboxes inside the legend and outside the chart.
Thanks, I didn't even think about out of chart options. I'm going to have to write more code than I'd like but this is going to work. Thanks for suggestion.
