this's my first time using Carousel panel and i watched on the videos that i can change the path the carousel panel so how can i change the panel path to act like MAC Dock...i saw it on the video but i don't know how?? i tried to change the path property but i don't know the equation.....please advise.
Best regards
Kareem
Hello Kareem,
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I suggest you use the following Path in order to have the XamCarouselPanel act like MacDock:
<Path Name="horizontal" Margin="0,0,0,0" HorizontalAlignment="Left" VerticalAlignment="Top" Height="Auto" Width="Auto" Stretch="Fill" Opacity="1" Data="M 9,250 C9,250 491,250 491,250 " Stroke="#FFB4B4B4" StrokeThickness="1"/>
You can also see how are defined different Paths in the Feature Browser under xamCarouselPanel / Layout and Behavior/ Define a Custom Path section.
