Hi there
i would like to create a Spline Series chart that has breaks (or gaps in the line every 10 (or preferably a variable amount of) points. The breaks would always be between two points Either that or change the line color between those 2 points. I created something similiar by overlaying a Column Series over a Spline to give bands but the output is a bit messy. Any ideas would be appreciated
If you insert double.NaN values into your data, the series should skip these values, creating a dicontinuity in the line. Does that help?
-Graham
Yes that is exaclty what I was looking for
Barry
