My chart is a Line chart and need to start from 1 on X-Axis. But when I set AutoRange="False" Minimum="1" Maximum="10" Unit="1", the "1" and "10" disappear. Does anybody know how to deal with it?
With the way that the category axis currently works it looks like you should set Minimum to 1 less than the first label you want to show and Maximum to 1 greater than the last label you want to show. The min and max relate to the index of the points in the series, not the value of the numeric labels you are using.
-Graham
But I need to make the chart start from 1. I don't want it left an empty area between the first value and the Y-axis.
unfortunately I don't believe there is a way to disable this margin currently, for the category axis.
