Is it possible to make fixed labels for a certain Axis in XamChart? E.g. the values for x-axis is "One" "Two" "Three" "Four", then I only need to bind the data for Y-axis.
The values for the X-axis label values are get from the DataPoint.Label property.
<igChart:XamChart>
<igChart:XamChart.Series>
<igChart:Series>
<igChart:Series.DataPoints>
<igChart:DataPoint Label="One" Value="5" />
<igChart:DataPoint Label="Two" Value="5" />
<igChart:DataPoint Label="Three" Value="5" />
</igChart:Series.DataPoints>
</igChart:Series>
</igChart:XamChart.Series>
</igChart:XamChart>
If you want to use databinding you need to bind and the label property as well
<igChart:Series DataMapping="Value=Value;Label=Label"…
In this case just set “One”, “Two”, “Three” as values of Label property.
Is it possible to set different Text labels on x-Axis for ScatterLine? Just like "TextOne", "TextTwo" and "TextThree"... each text is set individually and has no relationship between each other. But it should be a ScatterLine.
For the ScatterLine chart this is not possible. You can look at this post:
http://community.infragistics.com/forums/p/21975/239116.aspx#239116
