Hello,Is there any way to control the format of the information that is displayed when data is grouped? The default behavior is to show the grouped value followed by a count in parentheses. With some searching, I noted that there is something called GroupByRowDescriptionMask in UltraGrid, which seems to deal with this issue in that component. Is there something similar for xamDataGrid? (What I really want is behavior closer to the default in UltraGrid -- i.e. I would like the column name in front of the value -- this makes it more readable, especially if the data is exported to Excel.)Thanks in advance.
You can try an approach similar to this one.
That was the info I needed. It worked like a charm. Thanks!
