Hi, I have a line chart which shows a tooltip when the mouse pointer is used to highlight some specific areas on the data. But the problem is, that the tooltip is being shown for all the series/points. What I want to ahceive is that the tooltip should only be shown when the mouse is over a specific marker/data point, and not on the entire series.
Is that possible? How would I be able to do this?
Thanks in advance :)
Currently, when you set tooltip on DataPoint the tooltip is applied to the DataPoint and to the line. Do you think that the correct behavior is that the tooltip should be shown only on the point and not on the line?
