I am evaluating your control. I would like to use your control to plot live data from a DAQ card added asychronously to an observable collection or xml file. The datapoints are collected at a rate of 10 per second, time plotted on x axis, measured parameter on Y axis. Can your product handle this rate of data logging? If so can I add a scrolling feature to the x axis?
Thanks.
yes we can handle 10 updates per second, although if you have thousands of points, the performance might start to degrade to less than that. there are also some performance-optimized settings under the GridArea.RenderingOptions property that you can use to improve rendering speed.
we don't have a scrollbar feature implemented right now, but you can request a feature here: http://devcenter.infragistics.com/protected/requestfeature.aspx
