I have xamdatagrid i am binding with ICollectionView i want to provider adding,editing and deleteing record in the xamdatagird.I am using MVVM model.I am unable get the add feature in the grid.
Thanks in advance,
R.Ramesh Babu.
Could someone help with this?
Ramesh Babu.
Hi rameshbaburengarajan,
Could you please, provide me with some more details related towhat you are doing and what exactly doesn't work ?
I need the following things:
1. A simple sample application that demonstrates the issue.It doesn't have to be your real application - just attach the simplest sample that duplicates the issue.
2. Steps to reproduce the issue(through the provided sample application).When does the issue appear ? (describe what exactly you are doing)
3. What's the release version of your xamDataGrid component ?
4. What's the OS version you are running your application on ?
Best Regards,Yanko
CollectionView is one-way binding collection. That is why AddNewRecord is not available. BindingList<T> has two way binding support. If BindingList<T> is appropriate in your scenario, I suggest using it.
Alex.
What is the underlying requirement for a collection to be used in the XamDataGrid with the Add/Delete functionality? I have a custom collection that derives from CollectionBase and implements ICollection<T>, IEnumerable<T>, ICloneable, IBindingList, IList, ICollection, IEnumerable and is still does not work. Switching to BIndingList<T> does work however this is not a practical solution for my system.
Thanks for the assistance.
Add Record functionality requires two-way binding. BindingList<T> supports that. Some of the collections you have mentioned do not support them. IBindingList is the interface that BindingList<T> implements, so if your collection implements IBindingList there should be no problem with Add functionality. Maybe the problem is with implementing the interface. I will examine this issue further more.
the problem that has been described during the creation of a new data row still exists. Just use the reflector to get the Microsoft BindingList(T) implementation and copy it to your own project. When you bind to the copy of the microsoft implementation, adding does not work, when you bind to the original Binding(T) class, adding works. Seems that there is somewhere a dependency to the BindingList(T) class.
I guess its something with the AddingNew event. This event is just provided by the BindingList(T) class not by the IBindingList interface
Unfortunately, there seem to be no work around.
Greetings, Tom
PS : here is the microsoft bindinglist implementation that you can use to reproduce the bug. I renamed the class to BindingListEx(T):
[Serializable, HostProtection(SecurityAction.LinkDemand, SharedState = true)] public class BindingListEx<T> : Collection<T>, IBindingList, IList, ICollection, IEnumerable, ICancelAddNew, IRaiseItemChangedEvents { // Fields private int addNewPos; private bool allowEdit; private bool allowNew; private bool allowRemove; [NonSerialized] private PropertyDescriptorCollection itemTypeProperties; [NonSerialized] private int lastChangeIndex; [NonSerialized] private AddingNewEventHandler onAddingNew; [NonSerialized] private PropertyChangedEventHandler propertyChangedEventHandler; private bool raiseItemChangedEvents; private bool raiseListChangedEvents; private bool userSetAllowNew; [NonSerialized] private ListChangedEventHandler onListChanged; // Events public event AddingNewEventHandler AddingNew { add { bool allowNew = this.AllowNew; this.onAddingNew = (AddingNewEventHandler)Delegate.Combine(this.onAddingNew, value); if (allowNew != this.AllowNew) { this.FireListChanged(ListChangedType.Reset, -1); } } remove { bool allowNew = this.AllowNew; this.onAddingNew = (AddingNewEventHandler)Delegate.Remove(this.onAddingNew, value); if (allowNew != this.AllowNew) { this.FireListChanged(ListChangedType.Reset, -1); } } } [field: NonSerialized] public event ListChangedEventHandler ListChanged; // Methods public BindingListEx() { this.addNewPos = -1; this.raiseListChangedEvents = true; this.lastChangeIndex = -1; this.allowNew = true; this.allowEdit = true; this.allowRemove = true; this.Initialize(); } public BindingListEx(IList<T> list) : base(list) { this.addNewPos = -1; this.raiseListChangedEvents = true; this.lastChangeIndex = -1; this.allowNew = true; this.allowEdit = true; this.allowRemove = true; this.Initialize(); } public T AddNew() { return (T)((IBindingList)this).AddNew(); } protected virtual object AddNewCore() { object obj2 = this.FireAddingNew(); if (obj2 == null) { Type type = typeof(T); obj2 = Activator.CreateInstance(type); } base.Add((T)obj2); return obj2; } protected virtual void ApplySortCore(PropertyDescriptor prop, ListSortDirection direction) { throw new NotSupportedException(); } public virtual void CancelNew(int itemIndex) { if ((this.addNewPos >= 0) && (this.addNewPos == itemIndex)) { this.RemoveItem(this.addNewPos); this.addNewPos = -1; } } private void Child_PropertyChanged(object sender, PropertyChangedEventArgs e) { T local; if (!this.RaiseListChangedEvents) { return; } if (((sender == null) || (e == null)) || string.IsNullOrEmpty(e.PropertyName)) { this.ResetBindings(); return; } try { local = (T)sender; } catch (InvalidCastException) { this.ResetBindings(); return; } int lastChangeIndex = this.lastChangeIndex; if ((lastChangeIndex >= 0) && (lastChangeIndex < base.Count)) { T local2 = base[lastChangeIndex]; if (local2.Equals(local)) { goto Label_007B; } } lastChangeIndex = base.IndexOf(local); this.lastChangeIndex = lastChangeIndex; Label_007B: if (lastChangeIndex == -1) { this.UnhookPropertyChanged(local); this.ResetBindings(); } else { if (this.itemTypeProperties == null) { this.itemTypeProperties = TypeDescriptor.GetProperties(typeof(T)); } PropertyDescriptor propDesc = this.itemTypeProperties.Find(e.PropertyName, true); ListChangedEventArgs args = new ListChangedEventArgs(ListChangedType.ItemChanged, lastChangeIndex, propDesc); this.OnListChanged(args); } } protected override void ClearItems() { this.EndNew(this.addNewPos); if (this.raiseItemChangedEvents) { foreach (T local in base.Items) { this.UnhookPropertyChanged(local); } } base.ClearItems(); this.FireListChanged(ListChangedType.Reset, -1); } public virtual void EndNew(int itemIndex) { if ((this.addNewPos >= 0) && (this.addNewPos == itemIndex)) { this.addNewPos = -1; } } protected virtual int FindCore(PropertyDescriptor prop, object key) { throw new NotSupportedException(); } private object FireAddingNew() { AddingNewEventArgs e = new AddingNewEventArgs(null); this.OnAddingNew(e); return e.NewObject; } private void FireListChanged(ListChangedType type, int index) { if (this.raiseListChangedEvents) { this.OnListChanged(new ListChangedEventArgs(type, index)); } } private void HookPropertyChanged(T item) { INotifyPropertyChanged changed = item as INotifyPropertyChanged; if (changed != null) { if (this.propertyChangedEventHandler == null) { this.propertyChangedEventHandler = new PropertyChangedEventHandler(this.Child_PropertyChanged); } changed.PropertyChanged += this.propertyChangedEventHandler; } } private void Initialize() { this.allowNew = this.ItemTypeHasDefaultConstructor; if (typeof(INotifyPropertyChanged).IsAssignableFrom(typeof(T))) { this.raiseItemChangedEvents = true; foreach (T local in base.Items) { this.HookPropertyChanged(local); } } } protected override void InsertItem(int index, T item) { this.EndNew(this.addNewPos); base.InsertItem(index, item); if (this.raiseItemChangedEvents) { this.HookPropertyChanged(item); } this.FireListChanged(ListChangedType.ItemAdded, index); } protected virtual void OnAddingNew(AddingNewEventArgs e) { if (this.onAddingNew != null) { this.onAddingNew(this, e); } } protected virtual void OnListChanged(ListChangedEventArgs e) { if (this.onListChanged != null) { this.onListChanged(this, e); } } protected override void RemoveItem(int index) { if (!this.allowRemove && ((this.addNewPos < 0) || (this.addNewPos != index))) { throw new NotSupportedException(); } this.EndNew(this.addNewPos); if (this.raiseItemChangedEvents) { this.UnhookPropertyChanged(base[index]); } base.RemoveItem(index); this.FireListChanged(ListChangedType.ItemDeleted, index); } protected virtual void RemoveSortCore() { throw new NotSupportedException(); } public void ResetBindings() { this.FireListChanged(ListChangedType.Reset, -1); } public void ResetItem(int position) { this.FireListChanged(ListChangedType.ItemChanged, position); } protected override void SetItem(int index, T item) { if (this.raiseItemChangedEvents) { this.UnhookPropertyChanged(base[index]); } base.SetItem(index, item); if (this.raiseItemChangedEvents) { this.HookPropertyChanged(item); } this.FireListChanged(ListChangedType.ItemChanged, index); } void IBindingList.AddIndex(PropertyDescriptor prop) { } object IBindingList.AddNew() { object obj2 = this.AddNewCore(); this.addNewPos = (obj2 != null) ? base.IndexOf((T)obj2) : -1; return obj2; } void IBindingList.ApplySort(PropertyDescriptor prop, ListSortDirection direction) { this.ApplySortCore(prop, direction); } int IBindingList.Find(PropertyDescriptor prop, object key) { return this.FindCore(prop, key); } void IBindingList.RemoveIndex(PropertyDescriptor prop) { } void IBindingList.RemoveSort() { this.RemoveSortCore(); } private void UnhookPropertyChanged(T item) { INotifyPropertyChanged changed = item as INotifyPropertyChanged; if ((changed != null) && (this.propertyChangedEventHandler != null)) { changed.PropertyChanged -= this.propertyChangedEventHandler; } } // Properties private bool AddingNewHandled { get { return ((this.onAddingNew != null) && (this.onAddingNew.GetInvocationList().Length > 0)); } } public bool AllowEdit { get { return this.allowEdit; } set { if (this.allowEdit != value) { this.allowEdit = value; this.FireListChanged(ListChangedType.Reset, -1); } } } public bool AllowNew { get { if (!this.userSetAllowNew && !this.allowNew) { return this.AddingNewHandled; } return this.allowNew; } set { bool allowNew = this.AllowNew; this.userSetAllowNew = true; this.allowNew = value; if (allowNew != value) { this.FireListChanged(ListChangedType.Reset, -1); } } } public bool AllowRemove { get { return this.allowRemove; } set { if (this.allowRemove != value) { this.allowRemove = value; this.FireListChanged(ListChangedType.Reset, -1); } } } protected virtual bool IsSortedCore { get { return false; } } private bool ItemTypeHasDefaultConstructor { get { Type type = typeof(T); return (type.IsPrimitive || (type.GetConstructor(BindingFlags.CreateInstance | BindingFlags.Public | BindingFlags.Instance, null, new Type[0], null) != null)); } } public bool RaiseListChangedEvents { get { return this.raiseListChangedEvents; } set { if (this.raiseListChangedEvents != value) { this.raiseListChangedEvents = value; } } } protected virtual ListSortDirection SortDirectionCore { get { return ListSortDirection.Ascending; } } protected virtual PropertyDescriptor SortPropertyCore { get { return null; } } protected virtual bool SupportsChangeNotificationCore { get { return true; } } protected virtual bool SupportsSearchingCore { get { return false; } } protected virtual bool SupportsSortingCore { get { return false; } } bool IBindingList.AllowEdit { get { return this.AllowEdit; } } bool IBindingList.AllowNew { get { return this.AllowNew; } } bool IBindingList.AllowRemove { get { return this.AllowRemove; } } bool IBindingList.IsSorted { get { return this.IsSortedCore; } } ListSortDirection IBindingList.SortDirection { get { return this.SortDirectionCore; } } PropertyDescriptor IBindingList.SortProperty { get { return this.SortPropertyCore; } } bool IBindingList.SupportsChangeNotification { get { return this.SupportsChangeNotificationCore; } } bool IBindingList.SupportsSearching { get { return this.SupportsSearchingCore; } } bool IBindingList.SupportsSorting { get { return this.SupportsSortingCore; } } bool IRaiseItemChangedEvents.RaisesItemChangedEvents { get { return this.raiseItemChangedEvents; } } }
Does anyone get solution for - adding,editing and deleteing record in the xamdatagird. I have xamdatagrid i am binding with ICollectionView
