Is there a way or a possible work around to remove the spaces in between the chart data? For example, a bar graph that shows different chart data with each bar lying on top of the previous or the next bar without any spaces between them. How will I do this?
Thanks in advance.
The bars width by default is 80% of the available space, so if you multiply the width with 1.25 this will be the whole space.
