We are populating the DataPoints in a pie chart dynamically based off user options. Their could be 1 to X number of DataPoints so we want to let the control select the colors for the DataPoint.Fill. However we are creating our own legend for styling purposes. I want to programactically bind the DataPoint.Fill to my ellipse.Fill in my key, but have not been successful. If I populate the DataPoint.Fill with a color my binding works fine, but it doesn't seem to work with the chart's auto color. Is there something else I should bind to or is there an enum of your colors I could access to populate my key in the same order???
the first 7 colors used in the chart are as follows, the rest will be randomly generated...
_randomColors[0] = Color.FromRgb(0x46, 0x82, 0xb4); _randomColors[1] = Color.FromRgb(0x41, 0x69, 0xe1); _randomColors[2] = Color.FromRgb(0x64, 0x95, 0xed); _randomColors[3] = Color.FromRgb(0xb0, 0xc4, 0xde); _randomColors[4] = Color.FromRgb(0x7b, 0x68, 0xee); _randomColors[5] = Color.FromRgb(0x6a, 0x5a, 0xcd); _randomColors[6] = Color.FromRgb(0x48, 0x3d, 0x8b); _randomColors[7] = Color.FromRgb(0x19, 0x19, 0x70);
i'm not quite sure what you're trying to do with the binding, though; maybe if you posted some sample code i could help figure out what's wrong.
