Hi.
I wanted to ask if it is possible to disable the connection points on a node completly?
If the connection points on a node a removed, the nodes can be still be target to be connected with edges.
I want that specific nodes cant be target or even snapped to while i move a edge/connection.
Alex
Hello Alex,
There is a ConnectionConnecting event of the XamDiagram that is cancellable. If you are able to handle this event and mark e.Cancel to true to prevent the connection from happening let me know if the behavior persists or helps. Let me know if you have any additional questions.
