I am running into trouble trying to hide both axis labels and the grid lines.
The gridlines can be hidden if I make the labels visible and vice versa. Here is my xaml. Please suggest what I am doing wrong.
If I remove the Visible=False from the <igCA:Axis AxisType="PrimaryX" Visible=False>, the grid lines are hidden. The moment I add it back, the gridlines comeback.
<igCA:XamChart.Axes> <igCA:Axis AxisType="PrimaryX" Visible=False> <igCA:Axis.MajorGridline> <igCA:Mark Visible="False"/> </igCA:Axis.MajorGridline> </igCA:Axis> <igCA:Axis AxisType="PrimaryY" Visible=False> <igCA:Axis.MajorGridline> <igCA:Mark Visible="False"/> </igCA:Axis.MajorGridline> </igCA:Axis> </igCA:XamChart.Axes>
Thanks.
this seems to be a bug, so i entered it into our tracking system: BR35837. it will be fixed soon and released in a hotfix. in the meantime, you can try setting the stroke to transparent on the axis.
<igCA:XamChart.Axes> <igCA:Axis AxisType="PrimaryX" Stroke="Transparent"> <igCA:Axis.MajorGridline> <igCA:Mark Visible="False"/> </igCA:Axis.MajorGridline> <igCA:Axis.Label> <igCA:Label Visible="False" /> </igCA:Axis.Label> </igCA:Axis> <igCA:Axis AxisType="PrimaryY" Stroke="Transparent"> <igCA:Axis.MajorGridline> <igCA:Mark Visible="False"/> </igCA:Axis.MajorGridline> <igCA:Axis.Label> <igCA:Label Visible="False" /> </igCA:Axis.Label> </igCA:Axis> </igCA:XamChart.Axes>
