Hi, I have two collections
Collections 1 = starts from 0 and ends at 110 points (total 110 points)
Collections 2 - starts from 50 ends at 150 ( total 3 points)
Now my problem is I have used two category X-Axis by binding each to each collection and My chart shows different series with different Axes. Is there a possibility that I can show single x-Axis with specified Min value & max value? like it should start from 0 and end at collection two Max value + buffer(x).
Mahender rao
Hello Mahender ,
I had a look at your issue with the category x axis not showing the correct info. Due to the way the category x axis works the data must be flattened such that the categories are the same throughout. However, this can be accomplished without flattening your data by making use of our scatter line series (documentation: https://www.infragistics.com/help/wpf/datachart-scatter-line-series ) which you will be able to see in the attached sample.
wpfScatterLineSeries.zip
Hello Nicholas,
This is what I expected and works like charm. Thank you very much for quick answer.
Is there a way I can show tooltip with my values in line series? and how to disable the grid lines from chart for scatter line series.
For displaying tooltips you can set the showdefaulttooltip on the scatterlineseries to true. If you are looking to have a custom template for the tooltips for your series, you can take a look at this documentation: https://www.infragistics.com/help/wpf/datachart-chart-tooltips
For disabling gridlines you can set the majorstrokethickness on the numeric and Y axis to 0. You can find additional information in the documentation: https://www.infragistics.com/help/wpf/datachart-configuring-major-and-minor-intervals
