I have a xamchart columm based with a standard set of data 4 columns set to various values. Nothing crazy... but what I want to do is change the Y Axis instead of showing values, I want to change the labels to show something more meaningful. for example if you think of a scale from 1-10 incremented by 5 (normally you would see 0,5,10)... instead I want to show something more meaningful like the word "Bad" instead of 0, "Good" instead of 5 and "Great" instead of 10.
So basically I need a way to staticly set the value of each label on the Y Axis.
Thanks in advance.
Bryan
Sorry, this isn't a feature of the chart, so the only way to achieve it that I know of would be to overlay your own TextBlocks on the chart.
You can submit a feature request here: https://www.infragistics.com/community/ideas
