Hi there,
I have a XamDataChart with and want dashed yaxis but a solid line at zero. I have achieved this by setting the dash array property on the yaxis and adding a value overlay. My issue is that sometimes I can see both the Value overlay and the dashed lines at zero.
Other times this plots neatly. Any help much appreciated!
Hello Nick,
Thank you for contacting Infragistics. The DashArray properties apply to the entire chart and it won't be easy to exclude zero and draw a solid line. You may be able to work around this with two axis with the different dash arrays.
You can submit a new product idea to make modifying the axis gridlines more robust at <https://www.infragistics.com/community/ideas>.
Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
Thank you in advance to submitting your product idea.
