I'm using Infragistics 17.1. I have a xamDataGrid with group by turned on and HeaderPlacementInGroupBy set to "OnTopOnly". When I use the Infragistics Reporting Engine to print the grid, the column headers are not included in the report. If I don't group the grid, the column headers will show. Are there any special settings I need to set in order to include the column headers when printing a grouped grid?
This is the grid with group by enabled and column headers at the top only:
This is what is printed:
Column headers are printed if I don't do any grouping:
Harold
Hello Harold,
I followed the steps you suggested and was unable to reproduce the behavior you're describing. I created a XamDataGrid sample that has GroupBy with HeaderPlacementInGroupBy set to OnTopOnly. However, when I print the Grid column headers are included in the report.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
I have tested this using the latest version 17.2.1000. This might be an issue in specific version of 17.1 and might have been resolved in latest version. Please clarify the specific 17.1 build that you are using and I will modify my test environment accordingly to make sure this issue is fixed in latest version.
Sincerely,Sahaja KokkalagaddaAssociate Software Developer
XamDataGridSample.zip
Hi Sahaja,
Thanks for creating the sample. I should have done that myself first. Your sample works for me too. I'll have to try to figure out what's wrong on my side that causes the header to not be printed.
Thanks again for your help!
