i am converting application 12.1 to 16.1 i changed XamChart to XamDataChart using 16.1 reference but we not get some properties like Series,Series.Animation,Series.Marker,Marker in XamDataChart there are any new properties.
Hello Vineet,
While many things have changed in the XamDataChart compared to the XamChart control, the Markers, Animations, and Series related properties still exist. I encourage you to take a look at the following online documenation articles about these three parts of the XamDataChart control:
Series: http://help.infragistics.com/doc/WPF/2015.2/CLR4.0/?page=DataChart_Creating_Chart_In_XAML_Code.html.
Animations: http://help.infragistics.com/Help/Doc/WPF/2015.2/CLR4.0/html/DataChart_Chart_Animation.html.
Markers: http://help.infragistics.com/Help/Doc/WPF/2015.2/CLR4.0/html/DataChart_Markers.html.
I hope this helps you. Please let me know if you have any other questions or concerns on this matter.
Sincerely,AndrewAssociate Developer
How to use Pie chart in 16.1 version
how to handle Infragistics.Windows.Chart.DataBindEventArgs in version 16.1
To use the Infragistics pie chart in the 16.1 version of WPF, I would recommend that you use the XamPieChart control. You can read about usage of the XamPieChart here: http://help.infragistics.com/doc/WPF/2016.1/CLR4.0/?page=PieChart.html.
Regarding the DataBindEventArgs, the DataBind event does not exist for the XamPieChart. If you are looking for an event to handle immediately after the data binding occurs such that you can catch the ItemsSource being assigned, I would recommend handling the PropertyChanged event of the XamPieChart and check e.PropertyName for "ItemsSource," where e is the event arguments of the PropertyChanged event.
I hope this helps. Please let me know if you have any other questions or concerns on this matter.
