I have a line chart with NumericTimeSeries. The chart itself is inside a Panel and the User Control has several others panels. The tooltip for the chart only shows when the Panel containing the chart is floating when its docked the tooltips don't show. Is this a bug and is there any workaround?
Any help is greatly appreciated
I have the same problem.
Have anybody known how to solve the problem?
I can prepare test application with this problem if need.
If you can send us some test application it will be great.
I have сonditions already, what this problem shows up at.
Parent container AutoScroll = true and some other components cover the chart.
I can send simple test application, but I think it's my design mistake, not a chart problem.
Thanks a lot.
