I have a problem with a MDI Application with Ribbon as Menu Program.
When I open a Child Form with Toolbar (maximized), works fine. The form and his toolbar is placed under the MDI Form's ribbon.
When I open a form from Child Form or when I choose an other window, his toolbar is placed partially under the ribbon !I tried setting all the property about MDIMergeable (set No Mergeable !!!) !!!Thank you.
This looks like a bug. I would recommend submitting the issue to the support group: http://www.infragistics.com/gethelp.
I submitted the issue to the support group.
The final result is : Not a bug !!!And what is the problem ?
This somewhat annoying problem é and urgent, why do not work well the program !!!!
Thank you.
I must apologize as this was my fault. I was assigned to fix this bug and had forgotten about your original post describing the problem. I misinterpreted the description of the bug assigned to me and marked this issue 'Not a Bug'. I have been re-assigned to the issue and I have implemented a fix. Unfortunately, I did not find a workaround to use externally, so you will have to wait for the hotfix.
Do we know if this issue was ever resolved? I am having the same problem
This issue was resolved and I believe the hotfix was released. I would recommend upgrading to the latest hotfix. If the issue still exists, you might be experiencing a different bug which just happens to have similar results. In that case, I would recommend submitting the issue to the support group: http://www.infragistics.com/gethelp.
