Hi there,
I am facing an issue using a combo in a column of an UltraWinGrid :
- Column.DropDownStyle property is set to DropDownList
-The user got the focus on that column
-The user press the first letter key of an item contained in the list
Result =>The corresponding item is not selected whereas it should be.
-The user press again the first letter key of an item
Result=>The corresponding item is selected as expected.
-The user changes his mind and wants to press another first letter key of an item
Result=>The corresponding item is not selected whereas it should be.
-The user press several times (non deterministic amount of time) this same key
Result=>The corresponding item is selected.
When the Column.DropDownStyle is set to DropDown or DropDownValidate, there is no "focus" issue. Is there a reason to think that this behavior could be related to the DropDownStyle property ?Thanks,Thomas
I am working on the V10.3.
Hello Thomas,
I tried this with two different versions of 10.3 and 11.2 and was not able to reproduce this behavior.
Could you please let me know of your exact version.
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
