Hello team,
I want to create my own custom visual component using Infragistics.
E.g I want to create a UltraWinGrid with all properties such as row numbering, alternate row coloring etc properties to be set by default. I want to use such component directly rather than setting the properties for each such component ?
Can I do that ? Can I extend visual Infragistics component? Can you please provide me with an example ?
What you could do is to create a 'UserControl' and to inherit from 'UltraWinGrid', then set the properties you need, build it and use it as many times as you want. So as far as I understand your requirements you would not need to extend our control.
Please feel free to let me know if I misunderstood you or if you have any other questions.
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
