following problem:
I have implemented a custom tooltip that implements the IRenderLabel interface. Within the ToString method I want to access the DATA_VALUE element of the context hashtable. That works fine for my barchart but not for my custom layer that implements the ILayer interface.
I have set following properties for my primitive (which is a dot) within the FillSceneGraph event of the custom layer:
Dot.Caps = PCaps.Tooltip | PCaps.HitTest; Dot.Chart = UltraChart1.ChartType; Dot.Row = 0; Dot.Column = 0; Dot.Value = 5; // Set some value
But still I cannot access the DATA_VALUE from within the tooltip class. Do I have to set the DataPoint property of my primitive and thus implement the IDataPoint interface??
I hope someone can help me,
Micha
Hello Micha,
I try to reproduce your scenario in a small sample. Could you please take a look at the attached sample for more details and let me know if you have any questions.
Regards
Have you been able to resolve your issue ? Let me know if you have any questions.
