I am using UltraDayView v10.2 and i am trying to display AllDayEvent Appointment is AllDayEventArea.
I have following two problems
1) Here as the number of AllDayEvent Appointment increases, the Size of AllDayEventArea also increases which result in decrease in timeSlotArea. Is there any way to limit the size of AllDayEventArea and use vertical scroll bar if needed?
2) Also in figure attached you can see the appointment for next day gets shifted down, causing empty space in AllDayEventArea. Is there any way for not allowing appointment to get shifted down?
When i tried similar in Appointment Section of MicroSoftOutlook, i found my both problem were solved. I doubt why am i not able to acheive same appearance in UltraDayView. Attached below is the screen shot of MicroSoftOutlook where blue circle solves my first problem and red circle solves second one.
Any help and suggestion would be highly appreciable.
Bishwa
That would appear to be a bug in the control. A bug that was recently fixed may have addressed this problem as well, although it was fixed in 10.3 and later because 10.2 is no longer supported. I believe the fix will appear in the next 10.3 service release.
Hi, Brian
Thanks for your reply. My second problem is solved in version 11.1. But my first problem still exists in v11.1 also.
As the number of AllDayEvent Appointment increases, the Size of AllDayEventArea also increases which result in decrease in timeSlotArea. Is there any way to limit the size of AllDayEventArea and use vertical scroll bar if needed?
Am i missing any property?
No, there is no way to get vertical scrollbars in the AllDayEvent area.
Thanks for your time.
