I have an area chart and I'm using the FillSceneGraph event to do some custom drawing, etc. I need to force this event to fire under certain conditions. I've tried Refresh(), Invalidate(), etc. to no avail. Is there any way I can force this event to fire manually?
I'm using Infragistics v10.2.
InvalidateLayers() should do the trick.
Yep! That did it. Thanks again.
