When using UltraTimeLineView, along with UltraCalendarInfo and UltraCalendarLook, does anyone know how to display the column header times in military format? We want to see "13:00" or "1300" instead of "1:00 PM"
Hello KnappCL,
For any schedule controls, you can set the HeaderTextFormat property. For military time, it would be "HHmm".
Elizabeth AlbertLocalization Engineer
Thanks Elizabeth -- this property works great.
Is there a similar one to change the "tooltip" that seems to automatically display the date/time range when you hover over an appointment? I'd like to have its time in military format as well.
-Chris
Hello Chris,
I had to check with a developer on this, since there isn't a simple property to set it.
You can handle the AppointmentToolTipDisplaying event and get the AppointmentToolTipDisplayingEventArgs.ToolTipInfo.ToolTipText property. ToolTipInfo is a struct, so its value must be stored in a variable first. Then its ToolTipText can be set. After that, assign the variable to the ToolTipInfo property.
Thanks Elizabeth -- this works great!
