I have an UltraWinGrid and a column whose style is set to DropDownList and is bound to a ValueList of icons. If I set the ValueList display style to be "Picture" then I get about 5 icons worth of white space at the bottom of the DropDownList. If I do not set the ValueList display style and simply set the ItemHeight, the white space at the bottom of the list goes away however upon selecting an item, the selection is not shown until the control loses focus.
Is there a different property I should be setting or is this a bug in the control?
There's no reason why you should be getting any extra space in the dropdown, regardless of the display style. Can you post a small sample project demonstrating what you mean?
