I have attached a ultradropdown to a ultrawingrid as a valuelist in a columns as stated in:http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=7841. The column style is DropDownList. I want to change the text in another column when the user clicks in the dropdown, uses keyup or keydown in the cell, and when the user writes in the cell.
The click-event in the dropdown works fine, but keyup, keydown and keypress events does not fire on the dropdown, what am I doing wrong?
I'm using version 9.1.20091.1000.
Per
Solved that with CellChange Event on the grid.
