Hi!
Is there any chance to set margins for ribbons's application menu button in code or in app stylist?
I need to move button from left / top corner both 10px/10px.
Thanks for reply.
Hello jszyduk,
A possible approach to achieve this might be using a Creation Filter. You could read about it at: http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/Win_Creation_Filter.html.
However, I have created a sample for your too.
In fact this approach is not recommended because of the Microsoft Guidelines. You could read about this topic in the following forum thread: http://forums.infragistics.com/forums/p/5303/23913.aspx. There is an explanation from Curtis Taylor which is valid for this situation too.
Please do not hesitate to ask if you encounter any issue.
Boris, it works very well.
Thank you!
