im using ultramonthviewmulti calender control.. in that i need to display particular month of year ..
suppose if i click one button i need to traverse to particular date which is user entered in textbox.
thanks in advance
Set the FirstMonth property to the Month you want to display. You can get a Month instance form a date using the UltraMonthViewMulti.CalendarInfo.GetMonth method.
