I am using Ultragarph to display simple graphs and I was asked to refine the layout. My intention is to stay away from CustomLayout and I would like to know if the following requirements can be implemented just from adjusting available properties. The right image is what I need to have, the left image is what I have
1. Changing the orientation of teh TitleLeft
2. Centering the graph in the panel container
You can change the orientation on the left title with:
this.ultraChart1.TitleLeft.Flip = true;
You can control the chart position with:
this.ultraChart1.Axis.X.Extent = 50;
this.ultraChart1.Axis.Y.Extent = 50;
Hi Teodor,
does not compile. Labels have Flip property, titles do not.
I am working with Infragistics2.Win.UltraWinChart.v6.1.dll version 6.1.20061.28. Please let me know if Flip was added in subsequent releases.
Aurel
Aurel,
The Flip property was added to the TitleAppearance in NetAdvantage 2006 Volume 2. To use this you would need to upgrade to a newer version of NetAdvantage.
Alan
