Hi.
I'm using a grid which implements UltraGrid.
Now I try to handle some price-calculations in this grid.
The problem is, that the grid fires the
AfterRowsDeleted - event and also theAfterRowUpdate - eventBUT NOT the AfterRowInsert - event.
Is there a way to force the grid to fire the AfterRowInsert - event???
Thanks for help
AfterRowInsert will fire if you insert a row in the grid. Is that what you are doing?
The event is not intended to fire if you add a row to your data source or add a row in code - only when the user adds a row through the UI.
Hi
I'm expanding a 3rd-party-software and so i've no chance to change the way inserting the data.You're wright. The 3rd-party developer told me, that the rows directly are being added in the DataTable of the UltraGrid.
So i'll trap an event of the DataTable to handle price-calculating.
Thank you.
