I would like to replace the filter icon (FilterDropDownButtonImage) in all of my UltraGrids.
I see how to do it with code, but is there a way to set it instead with the AppStylist?
I have searched through the AppStylist controls, but do not see where the image is specified.
Thank you for any help.- Alexi
Hi Alexi,
I'm pretty sure this is exposed on the UltraWinGrid component role.
Go to the grid canvas and mouse over anywhere on the grid and press the letter "C" on your keyboard. This will take you to the grid's ComponentRole. You will see the grid properties available in the role editor on the bottom.
Hi Mike,
Yes, that is where I needed to look: - From the grid canvas, hovering over the grid, press C (UltraGrid role) - Infragistics Components | UltraGrid will be selected under Roles in the Style Explorer (left side) - In the Properties - Base - UltraGrid section at the bottom of the page scroll through the UltraGrid-specific Properties list for the FilterDropDownButtonImage and ImageActive.
Thank you. This saved me a lot of time.
Regards, Alexi
