Hi all. I have encountered a major problem with the UltraChart after the upgrade to 10.1. I have only tested the problem when using the chart as a GanttChart, but I have created a sample program which demonstrates the error (attached).
Basically, after the upgrade, GanttTimeEntry objects are not longer visible. After interogating the primitives during the FillSceneGraph event it can be seen that the Box object's Y and Height properties contain ridiculous values. The sample test project outputs the following screen. The two images below show the differences before and after the upgrade.
Using NetAdvantage for .NET 2009 Volume 1 UltraChart Control:
Using NetAdvantage for .NET 2010 Volume 1 UltraChart Control:
Notice how the GanttTimeEntries are no longer visible and note the extremely large Y and Height values.
Can anyone shed some light on this problem?
I think that the problem comes from the RangeType of the Y Axis as it does not have RangeMin and RangeMax values.
Try to change it to
Me.UltraChart1.Axis.Y.RangeType = Infragistics.UltraChart.[Shared].Styles.AxisRangeType.Automatic
and let me know if this solves the problem.
Yes. That fixed the problem perfectly. Thank you very much.
