Hello to all,
i have a UltraGrid and a problem with the column sorting.
If i use the C# nullabe type or String.Empty for DateTime (DateTime?) the sorting dosn't realy work fine.
Has anybody experience with nullable types or empty DateTime Value and UltraGrid or how to display and sorting null values with the grid.
The reason why i use the nullable or empty types is that we have date values in the database like this "01.01.0001". For all this values the grid should dislpay an empty column field.
Thanks and regards
Daniel
I find a solution that works for my problem
see: http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=7695
