To color a cell, you need to use the Appearance on the cell. The CellAppearance on the column applies to all cells in the column.
Typically, you would do this in the InitializeRow event. You might want to take a look at the WinGrid Performance Guide.
There is some discussion there about how to do this in the most efficient way along with some sample code.
