I am looking for ways to easily customizing UltraButton on my apps. Instead of rectangle look, it be more like capsule with 3-D look, and need to be able to change the button color to any color at runtime. Any suggestion how to approach this is greatly appreciated.
If you set the button's AutoSize property to true and use the ShapeImage property you should be able to get the button to look the way you want.
Set UseOsThemes to false, as well. Otherwise the themed drawing will override the BackColor.
Thanks for the help.
