I would like to colour one label X or the datapoint clicked on Line Chart. How can I do that?
I´m using vb.net.
it requires some coding, but this should give you the result you're looking for:
Public Class Form1 Private _currentDataPointSymbol As Symbol Private Property CurrentDataPointSymbol() As Symbol Get Return Me._currentDataPointSymbol End Get Set(ByVal value As Symbol) Me._currentDataPointSymbol = value End Set End Property Private _currentLabel As String Private Property CurrentLabel() As String Get Return Me._currentLabel End Get Set(ByVal value As String) Me._currentLabel = value End Set End Property Private Sub UltraChart1_ChartDataClicked(ByVal sender As Object, ByVal e As ChartDataEventArgs) Handles UltraChart1.ChartDataClicked If TypeOf e.Primitive Is DataPoint Then Dim dP As DataPoint = CType(e.Primitive, DataPoint) Me.CurrentDataPointSymbol = New Symbol(dP.point, SymbolIcon.Circle, SymbolIconSize.Large) Me.CurrentDataPointSymbol.PE = New PaintElement(Color.Red) Me.CurrentLabel = dP.DataPoint.Label Me.UltraChart1.InvalidateLayers() End If End Sub Private Sub UltraChart1_FillSceneGraph(ByVal sender As System.Object, ByVal e As FillSceneGraphEventArgs) Handles UltraChart1.FillSceneGraph For Each p As Primitive In e.SceneGraph If TypeOf p Is Text Then Dim t As Text = CType(p, Text) If t.GetTextString() = Me.CurrentLabel Then t.labelStyle.FontColor = Color.Red End If End If Next If Not Me.CurrentDataPointSymbol Is Nothing Then e.SceneGraph.Add(Me.CurrentDataPointSymbol) End If End SubEnd Class
