I would like to stack multiple Charts in a single Container. The vertical Gridlines and Axis should be painted above the whole chartarea, without any margins. This is what I get till now:
.. and this is how it should be:
How can this be done?
Haribert
the x-axes are already there, you just need to increase their LineThickness.
as for the y-axis, the best way to do this is to handle the FillSceneGraph event, create a Line primitive, and add it to e.SceneGraph.
Thanks for the replay.
Is there any way to further decrease the space between the two charts? Even setting Y-Axis to invisible doesn't decrease the space...
if you're handling FillSceneGraph you could just shift everything upwards in the bottom chart. but i think a better solution is to create a usercontrol, add a chart to the usercontrol with a Location like 0, -50 so that the top part of the chart is above the visible control area, and then vertically stack the usercontrols.
sounds like a very promising idea, i will try this out today.
